1 Wild R/T
Back in the day we would "Arc" the shoes... Basically mount the shoes on a machine that would sweep the shoe across an abrasive drum that would cut the lining off to match the radius of the drum....Thanks my friend, but I'm now leaning towards saying the Porterfield stuff isn't much better than the old-day
over the counter semi-metallics - which is to say, at this point, I'd rate the factory semi-mets above them
IF you can get ahold of the original asbestos-based ones.
After some time in service, I still don't have that "grab" a good set of shoes gives you - even on the first apply,
so I'm probably going to contact our resident NOS hoarder and fetch the factory stuff from him.
If you take a new shoe and press it against a brake drum whether standard sized or turned you'll find the shoe usually only touches in the center 30% or so... Arcing the shoes increases the contact area... Natural wear will do the same thing but it would take years to get the shoe hitting properly...
found this..
