Same here. 3/16" lines everywhere.
Who ever bothers to change the size of their hard lines?
Not many would.
Many factors come into play when
designing a braking system. Factory
set-ups are designed around GVW,
pad/shoe surface area, wheel cylinder/
piston volumes, pedal arm ratios, total
system fluid volume, master cylinder
piston diameter, caliper/shoe
bracket integrity. And must meet
a percentile of the driving public.
Your 150 lb wife can stop the car
at the same proficiency as your 300
lb linebacker son.
The system on my build took a month
or two of calculations before buying
any of the system components.
Pieced together with a hodge podge
of parts. My guess at final GVW was
3200 lbs. with the system designed
around that number. After everything
was assembled (interior, front and rear
bumpers, etc,) it came in at 3100 lb.
Each major part was weighed before
being added to the sprung/unsprung
weight. This info is needed for the
suspension calculations as well.
And the braking works very well.
Panic stop straight and level, all four
leave their mark from 50 to 0.
Vendors that sell aftermarket
conversions rely on an average of
performance as the system they
provide cannot fine tune for every
scenario of the system for your car.
Though, most are adequate.
Hope you can understand where I'm
coming from with this wall of text.
Anytime one deviates from proven
factory systems, there will be certain
issues that need ironing out. And
they're going to be different for
every car.
