SSBC has Original Spindle drum to disc brake conversions, among a few other companies
if you don't mind spending a few bucks more,
you'll "usually need a min. 15" wheels {or larger diameter} with the larger 11.25" & larger Rotors & 4 piston/6 piston Force 10 calipers
don't even have to change your drum spindles...
need to change to the disc brake master-cylinder & a proportioning valve for the rear brakes...
There are stock parts from NAPA, Summit Racing etc., that will work easily too,
find a listing for a disc. brake car in your year...
especially if you follow the instructions in the Disc-O-Tech link, that I posted earlier, pretty-much covers everything...
The Ram Man site
www.theramman.com has a ton of info too...
that guy is obnoxious as all hell, but he does have the knowledge base & parts available,
kind of pricey for what they are thou, but their Mopar Specific
