Break-in oil
sc440
11:28 AM
ohio
New 440, penn 30wt break-in oil sft cam. Did cam break-in, rechecked valve lash. Changed oil filter added another quart. How long should I run this before switching to non break-in oil?
I did break-in, changed oil and filter, ran it for 500 mi, changed both again, then annually from that point using VR-1.
While in break in process remove valve covers and with a helper rotate engine and check to see if all lifters are rotating.if any are not stop and inspection t
I marked lifters and push rods with sharpie and checked for rotation, when I checked Valve lash after cam break-in valves was no more then .002 looser then I originally set them.
Cam is a bullet custom ground mild solid flat tappet.
