superbee_68
Need some help with this fresh build, having some trouble getting it all dialed in. Here is a list of pertinent info to help diagnose:
1968 Coronet Wagon
1978 low mileage 440 from a motor home, average of 110 psi compression cold
Mopar purple 509 camshaft, 248 248 @.050", .509 .509 lift w/ 1.5 rocker, 108 lsa, 2,600 to 6,000 rpm operating range
New timing chain and high volume oil pump
Mopar performance single plane intake
QFT 750 cfm double pumper, 93 octane pump gas
Aeromotive 11203 fuel pump, Aeromotive return style pressure regulator, w/ return line, 10 gallon fuel cell, 6.5 psi fuel pressure
Full length headers, off-brand flow masters that dump before the axle
440 source billet distributor, running 16 degrees advance at idle, 36 degrees total timing
MSD 6-plus w/ MSD 12 volt blaster coil
Proform electric water pump, 35 gpm, thermostat with metering valve removed, basically a gutted thermostat
Jegs aluminum radiator and electric fans
All new wiring from Painless in the car
Dakota Digital gauges
727, manual valve body, 3,500 stall
4.88 gears w/ spool, Caltraks, drag radials
Quick history, bought the car as a nearly finished project, everything listed above was in the car, it just lacked wiring (not a single wire in the car when I got it). I spent the last two months wiring the car with a painless kit, getting it running, breaking in the camshaft, and getting it ready to go down the track. Although the build may sound a bit strange using a worn out old motor, the idea was/is to dial in the car on a low horsepower motor, while building a 500 in. monster to throw in it next year. There was plenty of money spent on good parts by the PO, so I guess I can see his logic, and will continue the plan.
The car fires right up, idles great, revs quick, and is generally impressive at lower rpm's for being a worn out old junkyard motor. But I have two major issues:
The engine stops pulling around 5,000 rpm or so, spits, sputters, pops, you name it. Once you grab the next gear, all is well again until you hit around 5,000 rpm again. Rev limiter is set at 6,000 rpm. I did a plug read, full throttle pull, killed the ignition while at full throttle, coasted to a stop, and pulled a plug. The entire ceramic looked like a nice tan color, except for a small darker/black spot near the strap. Seems like the AFR is pretty dang close, if not right on. I tried going both directions, smaller and larger, on the air bleeds for the high speed circuit, and nothing changed, car still has problems above 5,000 rpm. It pulls hard until it hits around 5,000 rpm. My only guess left is that my dakota digital tach is way way off and I am hitting the rev limiter. I am picking up the tach signal from the proper plug on the front of the ignition box. Any other thoughts? It's not exactly the same rpm every time, varies by 100-200 rpm. But this dakota digital tach is real bouncy so its hard to tell. The idea was to shift at 5,600 rpm and set the rev limiter at 6,000 rpm.
I cannot keep the thing cool. I get out of driveway, make one pull on a back country road, and I have to head home in a hurry before it over-heats. The fans definitely cannot keep up at idle, the temp creeps up and up slowly, with no end in sight. Looking up the fans on Jegs website, it looks like I have around 1,400 CFM total. The water pump is rated at 35 gpm. The aluminum radiator is huge, takes up the whole opening on the car, but it was a fairly inexpensive universal radiator form JEGS. My first thought was I don't have enough fan. Before I start spending money, any suggestions?
Like always, any and all advice is greatly appreciated.
1968 Coronet Wagon
