Bulkhead wiring repair
dan juhasz
1:23 AM
Whiting NJ
On a 67 gtx, my bulkhead connectors both sides are a mess. I dread the idea of replacing the under dash harness. This car has reverb am/fm, clock and air conditioning. The underdash couldn't be more congested and that bulkhead connector is behind the a/c case. Is there a better way?
Heh. I just did this on my Charger. First you remove the seat, then the AC duct to the outboard left, column trim, drop the column. I replaced the plastic bulkhead connector, released the #12 wires to and from the ammeter/fusible link and alternator. It can be done. A factory diagram, time and patience are needed.
