cable floorshifter conversion
HAMMER67
New Member
11:10 PM
St. Louis
I need some help with a cabled rachet shifter I plan to install in a 67 Satellite. 440>505 stroker on the build with 727 trans being beefed for the additional HP. Car was originally a column shift. Will I need original bracketry from a donor car or can this be done without? Any information will be greatly appreciated.
Is this an aftermarket shifter? If so, you'll just need the cable mounts and levers from the shifter manufacturer.
