Totally not needed... this whole thread is a non-issue.Groove the cam, problem solved.
Exactly. The bearing overlapping the feed hole is only a restriction if the cam is entirely out of the block. With the cam in place, the restriction is the bearing clearance.I agree.
Well...... sort of.
Those holes not lining up is not really going to be where the “restriction” is.
The restriction is the clearance between the cam and the bearing....... which will be way less area than the size of that hole.
Well, I'm going to go with it as is. I'll post here if I have any issues after the build is done...If the OP is worried, that would alleviate any worry.
That's like having an artery to your heart with a blockage. It may continue to beat, but why not deal with it now, instead of the engine heart attack later. I'd take it back, SHODDY indeed.Have them take it out and install a new bearing even if you have to buy a whole set. The shoddy install job blocks the oil supply by over half. Not ok in my book.
The #3 is not as critical as #2 & #4. As Hemirunner has said the bearing clearance is the important factor for a #3.Well, I'm going to go with it as is. I'll post here if I have any issues after the build is done...
I've disassembled several factory-built engines that looked just like the OP's.
It used to surprise me but after seeing how nice the bearings and cam journals were on those engines I came to the conclusion that it must not be all that critical. If it was, the factory would have taken more care to align those holes or Mopars would have a reputation as being "bearing eaters"....heck if anything you'll be pressing a little more oil down to that #3 thrust bearing.
The more important thing with cam bearings, to me anyway, is how the cam fits..
As mentioned, a non-issue. I was just commenting that the job could have been done with more attention to detail
