BSB67
Yes, and just like in 1970, it will be 9.7:1.Sixpack spec, 1970 engine build we are copying here.
Gonna be in the 10's comp. without a doubt.
The math is simple.
I made a recommendation based on experience with the recommended cam and a stock 440.What would you recommend? the heads will have big valves port work and a skim, the inlet will be port matched, rods are lightened and end to end balanced, six pack pistons, I'm guessing 10.5:1, It's a 4 speed with no power so not worried about vacuum, probably have the cam installed a couple of degrees advanced maybe going for an FBO ignition so plenty of advance.
Yes, very heavy pistons with lightened sixpack rods!If those are the TRW six pack pistons, they are HEAVY.
Mark
Got to be an 'old skool' 509 Mopar cam for me!
I've used several of the Lunatti VooDoo cams now and think the old cams are still better.
Modern cams are made of chewing gum and fail more times than not.
Just need to find one sitting on a shelf somewhere collecting dust...![]()
509 purple shaft, not nuts, pleasant thump to it. I’ve run the same old cam in 2-383s and my 440 with no issues whatsoever!!Got to be an 'old skool' 509 Mopar cam for me!
