Paint a yellow smear where the bolt touches the LCA, paint a line down on the bolts and paint or a thin strip of duct tape lengthwise on the T-bars, duct tape the camera really good under the car so it will see if the paint lines turn/move. Start the video and drive. Come back, view the video and look for the paint lines to rotated. You could see the adj. bolt turning or just moving down without turning.Thank you, that’s very good to know. That clears that up. I’m under the car now. Nothing is broke. Threads on adjusters are not stripped the slightest. A little rusty, but fine. They turn easily. This is extremely odd. I’m going to post a video showing what’s going on maybe next weekend. If it’s warm enough here. I can raise the car a thousand times, it will sit at that height for as long as I want. But, within several miles driving it. It drops back down. That tells me it’s losing tension somehow. But, I have no idea why ?
It’s hard to tell, by myself. But, not that I can tell. I just now raised ride height higher another quarter inch and I’m going to take it out for one more ride to see if it does it one more time. I ll report back on results.Just a thought, rear anchors for t-bars spinning?
Very good idea. I have a camera mount that I can attach to the torsion bar. I ll do that after today if it drops again. Great idea, thank you.Paint a yellow smear where the bolt touches the CA, paint a line down on the bolts and lengthwise on the T-bars, duct tape the camera really good under the car so it will see if the paint lines turn/move. Start the video and drive. Come back, view the video and look for the paint lines to rotated.
Tie the camera with a short safety cord, just in case the mount fails so you don't loose/destroy the camera. Make the cord short enough so the camera will not hit the road.Very good idea. I have a camera mount that I can attach to the torsion bar. I ll do that after today if it drops again. Great idea, thank you.
Yeah, I thought about the safety tie. I just pulled in my garage. To no surprise, ride height dropped again. Good news is, I think my driveline vibration isn’t there anymore. I found, I accidentally reversed direction on one axle shim. Now vibration at 70 is pretty much gone. . Might need, a couple more degree shims and driveshaft balanced.Tie the camera with a short safety cord, just in case the mount fails so you don't loose/destroy the camera. Make the cord short enough so the camera will not hit the road.
If you have a wifi camera that sends a video to a smart phone, you could take someone with to watch the picture live as it happens.
I will bud. I ll update. I agree, but I’m just mentioning what worked. I don’t believe the threads are stripped. I raised and lowered this car 30 times and can see that they’re not. But, sometimes old rusty threads tend to lose what they once were even without stripping them visibly. So, we’ll see. I totally agree, baffled me too.Makes no sense.. I still say they're stripped and you've just jammed them well enough with load to stay put for now. Get back to us next week...
I haven't worked on a whole lot of Mopars, but I have never seen it where the bolts turn easy nor so easily that I could use a ratchet on them.A little rusty, but fine. They turn easily.
I think you’re probably right. I think it’s worn out bars, fatigued metal. I can’t, think of any other logical explanation. Im pretty sure it’s not the adjuster bolts causing it. Otherwise, they wouldn’t lift the car time and time again. Plus, the threads are actually in quite good condition. All I know, is the car is staying up now. Weird, but I believe it’s fixed for now.I think I know what's going on. I had a similar issue when I rebuilt my front end. I changed everything except the torsion bars - thought I'd save some money. Mine was doing the same thing, settling back down onto the bump stops. I think the old torsion bar metal, after twisting thousands and thousands of times loses it's "spring" in the initial twist. You need to crank them up more and more as they get older, to get to the "newer" metal that hasn't been previously under strain and can therefore give some "spring" back the other way.
When your adjusting them on the jack you probably only need a few turns to get to the desired height but your not hitting the "new" metal. There's enough spring to hold the car up, but once you start driving they settle down again.
When you adjust them with the weight of the car on the springs you probably turned them more to get to the right height and therefore put the bar under more torsion than it's "usual" position and therefore it holds it's height.
You may be thinking now, what is this bloke talking about? You may be right - I could be talking bollocks. I just think of the old bar like a piece of elastic that's been stretched too many times - you need to shorten the elastic to get some tension. With the bar it just needs more twist compared to a newer bar.
I cranked the adjuster on mine a few times more (car still on the jack) and it's been holding fine ever since.
I have raised and lowered it myself many times. In addition, how many times it dropped on its own. I was looking for the height I wanted. Based on what height it handled best. I don’t live in Kansas. I have a lot of mid speed/sharp corners where I live. Mountain grades, old roads, etc. I was also taking into account looks, noises, etc. A lot of playing around.Well if you are absolutely certain that the threads aren't stripped and the adjuster position isn't changing... have you looked back to see if the crossmember TB sockets aren't rotted and twisting themselves off the car? Only other reasonable explaination as if the bars were indeed that worn out they'd have snapped by now. How many times have you turned the adjuster to lift this car an inch??? There isn't that much thread to do it repeatedly...
How is raising the front end changing your pinion angle?The problem is it drops ride height on its own after its adjusted. It drops down regardless of where it’s set. I need it to raise 1.5 inches. But, it won’t stay there. The rake is creating a bad pinion angle. If I raise the front end 1.5 inches, it fixes the pinion angle and vibration because the tail of the tranny is lowered in conjunction with the rear pinion. But, by the time I return back to my house. This happens, time and tim again ? It lowers on its own. For example: Top/middle of fender well can be at 26 inches from ground. I raise it to 27.5 with lower control arm and it will drop back down to 26 inches by the time I return.
