Cannot Remove Brake Pushrod From Rear Piston
boboh1
2:38 AM
Claremont,CA
Replacing my brake master cylinder. When I removed the old one the pushrod would not release from the pistons. I got this left to remove but it won’t budge. Is there a trick to this?
Clamp the rod in a vice with about 1/4 inch of space to the piston. 2 large screwdrivers one on each side and it will pop right off.
Thanks for all the advise. I do have a vice. Man it is in hard. All my other cars in the past the rod just slid out easily. Now I hope the bolts can be pounded out from the old MC
If you are reusing the studs, put on nuts to save the threads and tap them out with a hammer. Just tap them into your replacement MC. I had to use JB Weld to secure them into a new MC with larger holes. Worked well.
Mike
The "trick" was to pull it out while the master was still on the car. Do as Dadsbee says.
