This car:
Has stock based lower control arms, stock upper control arms, urethane strut rod bushings and Moog offset UCA bushings.
I have 5.5 degrees of caster and .75 degree of negative camber.
Do not be afraid of negative camber. Radial tires can handle it. My tires do not wear on the inside edge any more than the outside edges.
Camber and caster are connected. You cannot get much caster with zero or positive camber. You have to have some negative camber to allow enough adjustment to get positive caster.
The higher the front ride height, the LESS caster you can get. These suspensions are designed as such that as the travel nears the full compression (As low as the car can be) the caster is at it's greatest amount. See this chart:
This is an alignment graph of a 73-76 A body but it is close to what a B or E body would have. The -2.25 is actually rise/extension....essentially 2 1/4" over stock height. Note that the caster starts at 1.77 degrees at 0.00. (Static ride height) 2 1/4" lower than stock, the caster sits at 4.892 degrees.
My point is that a car that sits higher than stock will have trouble obtaining enough caster. A car that has zero camber will have trouble too. If your car has a profound rake where the rear is higher than the front, that will make it difficult too.
