DodgeBall
Modern cats will make a huge difference. I know someone who took cats off of a stock modern V8 and the car stinks like a 60s car. As stated by others, mount them as close to the manifold as possible. Use the newest cats you can find (or quality aftermarket replacements for a new car such as a V8 Challenger or Mustang GT). I know your engine is big, but a cat that is a little on the small side is probably better because it will heat up quicker and stay hotter (yes it might cost a little horsepower up top). Don't get high flow. Get cats designed for a car that only had two cats from the factory...you don't want two from a car that was designed with four, because they may do different things. Make sure your fueling is dialled in because a rich mixture can wreck your new cats. Just in case that happens, I'd suggest clamping them in place rather than welding them...use some high temp sealant to seal them up. Good luck!
