My 67 GTX hasn't been run in 3 months due to a bad radiator. Finally had it re-cored and installed new water pump. When I finally started it today, the battery spun it over OK. It took 4 primings of the carb and key starts before it filled the carb and kept running so the battery seemed to be doing it's thing.
After I got it running, I engaged the AC and let it idle while I topped off the radiator and sealed everything up. I sat back down inside and noticed the voltage was low - about 10 - 10.5 volts at idle with the AC compressor engaged and fan on high and the dash amp gage was showing discharge. I have voltage and oil pressure gages under the dash. I reved the motor up some but the voltage did not increase hardly any. It typicaly use to run about 14 - 14.5 volts or a little more once above about 1000 rpm falling to maybe 13 at idle with the AC on. I killed it and then re-started it and the starter seemed to turn a little slow so I decided to charge the battery.
I put a battery charger on it for a couple hours (slow charge rate) but although showing close to 100% charge it never did fully charge and go into a float stage. Voltage across the battery posts was about 12.6 V.
I decided to venture down the road in the car and see what it would do. It re-started fine but still had very low voltage. I turned the AC off and the voltage jumped up about 1.5 volts - maybe a little more. Turned the AC back on and the voltage drops back. But even with the AC off the voltage doesn't get back to the 14 - 14.5 volts it ran before. With the AC off the amp gage reads slightly positive but at 50 mph the voltage was only reading about 12.5 to 13. When I got back I killed the motor and it re-started fine.
I've had this car about 10 years and it has the usual rebuilt alternator on it of questionable output. I put a solid state voltage regulator on it when I first bought it and it has seemed to work OK - at least up until now.
How do I best trouble shoot this thing? Electrical is not my strength as beyond knowing enought to not hold a spark plug wire to my tongue - my skills are about tapped out. The shop manual isn't a lot of help as it mostly discusses testing components rather than basic system checks. I'm tempted to put a new rebuilt alternator on it but then I wonder if the voltage regulator has crapped out. And then the high voltage drop when I turn the AC on makes me wonder if the fan motor has about kicked the bucket and is pulling high amps. The battery could be an issue but it seems to be holding up. I'm leaving it on a charger tonight.
I have a decent multigage electrical tester and a few other things like a test light, so I can do some basic checks if anyone has any suggestions. I've read the trick of pulling the positive battery cable with the motor running is not a reliable test of the charging circuit and doesn't help pin-point the problem. I may still have the old mech voltage regulator also that I could re-install, but I will have to look for it.
Another note - I have a green knob battery disconnect on the car and I have problems with it not making a good connection but I assumed that would only cause a starting problem when amp draw was high.
Thanks in advance for any help.
Dan
Dan
