Canadian1968
I just went to a 2 electric fan setup . I belive the fans are only rated for 7.5 amps each.
I do have a newer alternator bought it 5 years ago now... I forget the specs . The car is using mopar electronic ignition, with 0 problems . I am running a piggy back wire upgrade from the alternator to ammeter and back to battery eleminating the bulkhead .
Testing out the new fan setup , threw my test leads on the battery it's reads steady 12.7 V . The ammeter is reading is just below the first mark (20). Not so worried about the 20 amps .... more so the 12.7 V . I guess it's not discharging but it's right on the line.
I read in a couple other post about running a wire from the alternator directly to the fans ?
