383man
First thing I would do is check the charging system and see how many amps the alt will put out. Even though you have a voltmeter on the circuit you still need to know the alt amps to diagnose the charging system. What is the rated amps of the alt on the car ? It seems to be charging but not as well as it should. I have even seen battery's take in many amps but not bring the voltage up when there was a battery problem. When I had the stock 35 amp alt on my 63 it would drop to about 12.5 at idle at night with the electric fan and headlites on. But as soon as I hit the gas she came right up to about 14.2 and styed there unless back at idle with all loads on. I switched to a 100 amp alt so it will now charge enough even at idle to keep battery volts at 14.5 with all loads on at idle. I would definetly check your alt amps output at 1800 rpm with all loads on and see what it is putting out. Ron
