No. They are intended to reflect true gross flywheel. It does not say it explicitly, but when you play around with their numbers and formula, it becomes apparent.
having played with a chassis dyno with my '69 r/t i believe true horsepower loss with a stock converter, exhaust, and gear is about 21%. chrysler says the net horsepower for a 440 tops out at about 330hp; that's about 260 or so at the tire. i believe these numbers to be fairly accurate. my stock 440 won't run 5000rpm. in fact about 4600rpm is all it wants and that's the rpm the factory rated peak power. mine would go flat at around 4300rpm on the dyno and that's with a 6pak (stock converter, gear, exhaust; peak power was 327hp).
327 at the tire, 107.92 trap speed, 4060lbs, 3.23 gear, stock converter. unfortunately i never worked with the combo because et's were frustrating. later found that some of the e.t. issue was me using the wrong distributor. the 289hp thing was my first trip to the dyno. i was looking for some answers as to why some things weren't working well. believe i had a head gasket give up and maybe some fuel issues. like a dummy i never kept notes back then like i do now so maybe some dog chasing the tail thing,...?Lew, do you still have your old R/Ts chassis dyno numbers and corresponding track numbers? I seem to recall you measured 290 at the wheels, but that 4000lb beast was trapping at 105 mph. Do you remember?
My Charger’s fwhp verses rwhp show 21% drivetrain loss too, despite the notable hp difference between our cars
Got a link or post pics of article?an interesting read is the september '70 popular hot rodding issue with a '70 6pak chassis dyno/drag strip test. i don't know how many times I've read that article. good info for somebody doing stock or near stock stuff.
They are tuning devices. I don’t get very excited about someone’s chassis or engine dyno data. The real equalizer for me is a time slip and atmospheric data.Either hot rod or carcraft did a local chassis dyno crawl thru five chassis dynos, with a stone stock blown Shelby mustang. Around 600 (rated) crank horsepower. (I don't remember if it was an auto or six speed)
Chassis horsepower results varied from one dyno to another by MORE than a hundred horsepower!
Agree. Knowing how easy it is to "fudge" results to make the customer happy, I tend to discount most instances of huge numbers. E.t. slip is the determining factor, but how much of a race setup the car is, is definitely a factor.They are tuning devices. I don’t get very excited about someone’s chassis or engine dyno data. The real equalizer for me is a time slip and atmospheric data.
Racer A may really have 700 hp, but if it's in a 4000 lb car with a 2800 converter and 3.23 gears, and T/A radials, he's gonna get smoked by Racer B, with 3200 lbs, 5000 converter, and an honest 500 hp.
Again, agree. Mph is a much better determinate of horsepower, E.T. a better indicator of how well a drag car is set up.Sure.
My reference to “time slip’ verses et was purposeful. Mph generally neutralizes differences in suspensions. I did fail to mention race weight though.
