Hello, I have a 1966 Belvedere and i replaced the engine bay and headlight harness with new. I have the negative side of the battery hooked up and the positive lead is unhooked. I'm using a test light between the positive post of the battery and connecting the test light to the positive battery lead. The tail light harness is already installed but I did not hook up the headlight harness yet. All fuses are in and the test light did not light. I'm thinking that is a good thing?
Now when I turn the key on the test light, lights. I removed one fuse at a time and the test light lights, I removed all the fuses, left the key on and the test light is still lite. Is this normal? Or is something wrong? Thanks for any suggestions or help. Rick
