RT68440
I used a combination of things. I used 3M strip discs and wire wheels to get the heavy stuff, then I’d go over everything with 80 grit on a DA, then I’d hand scuff it with a maroon scotch brite pad.
I thought about that. It's going to be in the garage while I do the bodywork and priming, blocking etc to the engine bay and underside of the car. I know that no matter how good I try to keep the motor clean it's going to get dusy. It's not a huge deal but I'd rather paint it once I do a full clean on the garage and am closer to installing it.Motor is looking real good. Got to ask though. Why wouldn't you paint it now since you are in the timeline that doesn't require scuffing? Did you ever find your fender tag? I would be interested to see the color combo since it is such a rarity.
Will do, thank youLooking good. Make sure you check the fitment of that rear AMD glass with the opening and your trim. There has been a lot of problems with it because the curve in it is not correct. Most guys were sending them back and finding a good original. This was up to at least a couple years ago. Maybe they got the problem corrected by now, idk.
I just so happened to see a post on Facebook where someone posted a picture of them sitting at their door step. I called Kelsey Tire that day and they were shipped that evening.Nice, neither Vintage Tire or Coker could be bothered to tell me that the Polyglass are back in stock !
