HS 69 Charger
Seems a bit of personal taste on the SureGrip model. I did end up going with Auburn (which according to another thread was the original OEM design). I also chose to go back to my build sheets gear ratio so picked up Yukon Gear and Pinion set.
One follow up question. The Auburn SureGrip Diff came with a Limited Slip Additive bottle to add into standard Gear Lube. But when I checked local stock of Gear Lube I found Lucas Conventional Oil 80W-90. But on the back it says exceeds Service Level: MIL-PRF-2105E and PG2 Limited Slip. So two things: My Service Manual says use MIL-PRF-2105B. I expect this means we are beating it with the 2105E.
But my bigger question is PG2 Limited Slip. So does this mean I still use the Auburn Additive or NOT.
Thanks for any advice on this.
