I've had a very frustrating intermittent starting issue with my 360 powered '78 Magnum ever since I bought it nearly 2 years ago. It will crank with not even a hiccup some times, then after several to as many as 5 or 6 attempts at cranking, decide to fire up. I went through a period last month where it was usually starting on the first turn of the key, and I thought maybe the problem was fixed. Then at a cruise when I went to leave, it wouldn't start and after a half hour of me and some people there at the cruise helping out, it finally decided to fire up. It gets fuel, it just seems like it isn't getting spark when in the cranking position of the ignition.
Otherwise runs perfectly, I just need it to start!
All the lean burn stuff was removed prior to my ownership and has a Mopar electronic ignition, orange ECU box etc.
It doesn't help I'm not very good with electrical issues, so I've been chasing this issue since last year, replacing the ECU, ballast resistor, cleaning up the ground on the ECU etc.
The other day my friend brought over his multimeter and did some checks. One thing that caught his attention was he was only reading 5.5 v going into the coil. I checked with another guy I know who is knowledgeable on electrical and he said it should be 12 v.
Is that correct, and if so, what would cause the voltage to be low? The guy who is good with electrical troubleshooting said a weak battery or bad voltage regulator can cause that problem. Does the voltage regulator even tie in with the voltage to the coil?
