Collection of Parts for 392 Swap
Fab’d up the patch for the wiper motor bulge clearance. Patch for the clutch cable clearance. Also found the USCT TR6060 trans mounts sat too low at proper drive train angle with the QA1 coil over K frame. Fab’d up new tabs to lift the mounts up closer to the floor to make room for the exhaust. Welded the mounts into place, connecting them to the cross frame. Next step is getting the firewall and underside prep’d for paint.
Took advantage of the Holley black Friday sale and got myself an E body pistol grip shifter and shifter boot for the swap. My non console B body pistol grip was not going work with TR6060.
Finished up welding in the trans tunnel covers, welding in a patch to fill in the front half moon clearance in the support arch, cutting out the shifter clearance in the arch and cover. Also cut out and fab’d in a pipe for e brake cable clearance in the SFC. And made some seat mount stiffening plates for the passenger side.
Waited for a warm day and blasted the shop with propane heaters to get it toasty warm so the car could get up to a nice temp to get some painting done.
Gave the trans a scrub and then two coats of Mopar Street Hemi Orange paint just to be different.
Rattle canned the engine bay and front frame rails with satin black frame and roll bar paint. Coated the undercarriage with a coat of primer and then two coats of rattle can spray on bed liner. Was a bit of process painting without it being on a whirly jig but I’m happy with the end result.
Next up when the temps are back above freezing next week is seam sealer application at all possible leak points in the firewall and trans tunnel.
Got the TTI headers installed today. After swapping out the original starter for the mini, they bolted up fairly easy. The head gaskets stick out past the head and the block so I needed to bend the excess down slightly so the header flange would slip past it.
Applied seam sealer to the underside. Covered up the welded areas and made sure to fill all gaps that could let moisture in.
Did some chopping and modifying to the underside of the 2020 challenger console for some test fitment on the new tunnel. I’m going to use some aluminum to fab up covers for the gaps in the front and back. Flex the the front flare of the console tighter to the tunnel and attach the carpet to the underside to fill the rest of the gap. After it’s all mocked up I’m going to paint it with Herbs brilliant blue (B5) paint.
The armrest feels great at this height. The position it’s in now lines up pretty good with the shifter position as well. And it’s going to be awesome to finally have some cup holders!
Decided on a direct mount shifter for the TR6060. Went with the Racetuning base with positive stops. I’m very impressed with fit and finish as well as the feel of the centering for 2nd to 3rd shifts. Highly recommend! Customer service was great. Fast replies to text messages also very helpful.
Picked up the USCT DBW pedal adapter bracket as well. Feels good and sturdy, lots of adjustability. Need to shave a bit off the side so it fits around the firewall eyebrow though.
Also installed the skip shift delete plug and the reverse lock out electric solenoid to spring replacement ordered off Amazon. Merry Christmas to me!!!
Some progress from this week.
Mounted the Leed Brake booster and Wilwood master cylinder. Not a big fan of the install instructions for booster bracket and the linkage in the interior. Need to get a LH bracket for the Wilwood proportioning valve, can’t mount it with the RH bracket due to the fender interfering.
Four core Frostbite rad and Frostbite fan shroud. Not impressed with the lack of mounting hardware for the shroud and fans.
Installed the drive train for what I hope to be the last time. Lots of room between the Holley mid mount and the cooling system. TTI headers have lots of room and clear everything.
Shifter clearance is tight to the driver side. Need to carbide burr a bit more so it doesn’t touch going into second gear. Notch another 1/4 off.
Looking forward to getting the QA1 coil over suspension and steering rack installed. As well as fitting the Flaming River tilt column to the rack next week.
Pic of the trans mounted with customized mounting tabs.
Installed the power rack. There’s not much room between the hydraulic lines and the Holley oil pan. Just enough. The rack fits in with the 45 deg filter adapter.
Used 120 mil Siless sound deadener on the firewall, floor, trans hump and up the back. Might have went a bit overkill, it’s not a race car so a bit of extra weight for some sound proofing and heat shielding is ok. Used just under 60 square feet to cover everything pictured. Have 50 mil Siless for the doors, roof, trunk and trunk lid yet to be installed. Might even put some on the underside of the dash. Putting a decent stereo with subs in it so I don’t want rattles.
Have to travel for work, so nothing getting done in the next 3 weeks.
