Cometic head gaskets
dan juhasz
11:06 PM
Whiting NJ
Are cometic head gaskets for a 426 ( 5 layer )installed as is ? No spray sealers or silicone in any common leak areas?
I install dry. I only use spray sealer when re-using them. Also make sure to have the correct deck finish surface of 50 RA (roughness average) or finer, is recommended for a proper gasket seal. Anything rougher may conflict with the gasket design.
Block has never been decked. Is the factory surface adequate?
Yup, the 'sealer' is the coating on the gasket.....
