The only way you'll know if it's a perfect fit is if it's measured. We are talking .000X press. Can you measure to .000X accurately at home? This would be micing the crank (.000x readout). And then measuring the dampner bore with a tool like a Sunnen rod hone machine or dial bore gauge (.000x readout). If not, you don't know if it fits correctly. Have I done it like that? Yes. Did it work? Yes. Was it correct? Who knows. Can't blame failures on the manufacture if the part installation was suspect. In my case, my Fluidamper cracked and leaked. Why? It was sized correctly. It was also used when it was purchased. So who knows why it failed. Just because you can pound it on doesn't mean the fit is correct.
Doug
Doug
