Comp Cam ID Help
w.Hudson
3:22 PM
South Louisiana
Anyone have an older Comp Cam catalog ?
Need help with ID and specs on this cam.
It should be a solid flat tapper cam for a 426 Hemi
Thanks
Call Comp Cams! They know their numbering system, and you even have a serial number so I will bet they can tell you exactly what it is. They have identified an old custom ground cam just from the etched numbers on the back of the cam.
Lobe #264-1 is from the “High Energy” solid series:
264@.015”
220@.050”
.2933” lobe lift
I’d guess that’s a single pattern cam on a 108 lsa
