PRHeads
- 11:33 AM
- Aug 31, 2018
- So. Burlington Vt
Oh yes I have used these rockers.
The question was...... have you used the Comp rockers on the TF heads?
The pieces don’t physically fit on the end cylinders because the end stands extend towards the rockers beyond the edge of the hold down clamp.
All that’s needed to make everything fit is to remove about .030” of material from the stands so that the shaft hold down clamp is what the rocker butts up against....... and not the stand.
Relieve the two end stands....... everything fits fine.
I have not run into this situation using the Comp rockers on any other heads.
