RRSweden
Hi again.
Here's a thread for those who wants to give a rookie some input on a choice between two cams.
(some of you knows about my build from earlier, but here's what I've got)
383, stock rods, 1.900 flat top pistons, 915 heads (3-angle cut 2.14/1.81) unported, Edelbrock dp4b intake, holley 650dp, headers, stock dist.
Goal is a good, fun to drive streetcar capable of a few runs on the strip/year.
cam 1
Comp XE268h
Basic Operating RPM Range: 1,600-5,800
Intake Duration at 050 inch Lift: 224
Exhaust Duration at 050 inch Lift: 230
Advertised Intake Duration: 268
Advertised Exhaust Duration: 280
Intake Valve Lift with Factory Rocker Arm Ratio: 0.477 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.480 in.
Lobe Separation (degrees): 110
Cam 2
Custom made (Lunati) cam
Basic Operating RPM Range: 1,500-5,650
Exhaust Duration at 050 inch Lift: 234
Advertised Intake Duration: ?
Advertised Exhaust Duration: ?
Intake Valve Lift with Factory Rocker Arm Ratio: 0.466 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.488 in.
Lobe Separation (degrees): 114
cam 1
Comp XE268h
Cam 2
