Not sure if this was in humour or for real. I have to take my dash trim apart to change the bulbs. One bulb keeps going out but eventually turns on. I think one of the bulb sockets are not seated right.one of the dash lights was out I showed his wife how to reach up behind and change the bulb. I can be helpful like that.
This is the dash cluster I customized in my Cuda. The dash came apart really easy and went from there. I wanted to do the same for my 77 Cordoba but I found out the complete front dash, top to bottom, has to be removed. Looks like too much work.from scratch, I'd grab my box of extra standard clusters and bezels to use for mock up.
I wanna say I've done it in 15 minutes. Ok, boneyard and 1/2 the dash removed already but it's not horibble.This is the dash cluster I customized in my Cuda. The dash came apart really easy and went from there. I wanted to do the same for my 77 Cordoba but I found out the complete front dash, top to bottom, has to be removed. Looks like too much work.
That seems easier than I thought. I will have to rethink this. Maybe part of next winter project. I want to get my steering wheel redone to fix the multitude of cracks so this may be a good time. Thanks for the input.I wanna say I've done it in 15 minutes. Ok, boneyard and 1/2 the dash removed already but it's not horibble.
Top and bottom bezels, hvac controller, radio, head light and wiper switch. Remove metal plate under radio / hvac, unbolt column from carrier but leave in car. Take off dash pad, unbolt carrier, pull it forward, unclip the wiring harness, done.
Luckily I don't have power windows or doors. Thanks again.It literally is that simple and here's the bit that isn't: if it has power windows / locks, the harness that connects both doors, relays, power feed is clipped to the back of the gauge carrier. Best guess is order of assembly. As in: hang this harness from that before ya shove it in.
Makes it very annoying when you just want to grab the power door harness because you've got to yank the carrier to detach the dumb thing. Rest of the body harness, no.
Finally had a conversation with the current owner - it is in fact the Russo / Steel car minus the continental kit and Kelsey Hayes. Yes, he actually managed to score a complete NOS stripe kit.Sure looks like the same one - except for the tape stripe. Newer pics look the 77 factory stripes and good luck finding those.
I was working for one of the biggest Caddy Dealers in Cleveland ,I'm thinking Hess was the company that did all of caddys till Cadillac starting marking there own and boy did that strip the **** up with Caddy peopleOh, I recall people were plunking down serious $$$ for the Eldorado, the "last" convertible !! Lol !! What a joke !
Unconfirmed rumor says this car rescued, fixed, painted red, last known Kansas? area.Wendel forwarded this one to me near the end of 2010 - another tan one and another column shift car. The thing I find uber weird about this one is the burgundy interior. The pic from the back makes it look like Emess added a filler panel to the sail panel when they cut the top off.
The seller said they impounded in San Bernardina, CA with 53k on the clock and that it sat in their impound yard untouched for 8 yrs after that. Said they had paperwork for it but I never got an ask price. Suspect it could have been had real cheap and yes, I have an extra windshield in my stash.
