correct me
plowman
12:04 AM
michigan
if I'm wrong correct me. The kv fuel hose goes where indicated in picture, kv hose to fuel filter another kv hose from filter to fuel tank correct
The only filter at the rear of the car is the filter sock on the pickup tube inside the tank
Exactly!
Just a side note. If you have a 440 car you should have two lines - one being the 1/4" vapor return from the little black can by the fuel pump.
Yup. That black can is a vapor separator and is available as a reproduction part. OR...there are aftermarket filters that can be substituted due to a 1/4" third nipple (in this case, not superfluous) lol
