Flathead38
This should be fun... I provide the clues, and you pick your favorite explanation for what I found... See my intro post, "Wakening a 1969 Charger from a long slumber", and "Newbie 318 questions" if you want more background.
Update on '69 Charger resurrection... Original "675" heads failed magna flux; they had multiple cracks between valve seats and/or valve seat to spark plug hole. So began a search for rebuildable heads.
We bought a cheap tired 318 long block as a spare, minus the valve covers, intake and push rods (Clue #1), because the heads were also "675", the same as our old engine. For grins, ran a leakdown test on the spare engine. Most cylinders were around 70/80 (Clue #2), with the sound indicating that worn rings were causing the majority of compression loss.
Then we pulled the heads. We saw valve to piston contact on EVERY valve (see attached pictures, Clue #3). That's the mystery part. What's your favorite explanation for how this likely happened? I can think of a few plausible scenarios, but it will be more fun if I don't provide them... Also curious to hear, based on your favorite theory of how this happened, what other damage I might expect to find as I continue the disassembly.
The good news is that this engine is all 1970, and appears never to have been opened up since new. Lots of original paint on the exterior. Cylinders measure out at STD +.002, and the walls look decent. I haven't pulled the valves out of the heads yet, but anticipate that I may see bent valves, and possibly cam damage, although the cam looks very tired and likely junk anyways. No hardened valve seats is also consistent with untouched 1970 heads...
If the head castings are rebuildable, I figure what I paid for the spare engine is probably fair. If the block can be rebuilt at .010" over, or maybe .020", I would consider it a pretty good deal.
