dart master cylinder
Dan T
11:04 PM
Southern California
question: I am putting new brake lines and all parts on my 62 dart, I am using 3/16 lines for rear and front (rear drum/front disc) I would like a good recommendation for the master cylinder (will not be using booster)
thanks in advance
I like the aluminum, 2 bolt Mopar style. You will need a adapter plate (make one) and may need a adjustable push rod. Just use a adjustable proportioning valve to tune the bias pressures.
Mike
Mike
Thanks for the information, I will get it put together
Did it on my 62 with these parts:
Adjustable Proportioning Valve
Mopar Aluminum Master Cylinder Kit
