Dash harness connector ID 70 Roadrunner
Ftlbs
1:09 PM
Virginia
I'm installing a new dash harness and having trouble with a few connectors. One is near the glove box, one is behind the cluster, and one is to the left of the wheel. Any help is greatly appreciated.
It would help to know what year and model Simca you are working on.
Your very right photo the connector is for the radio.
Your top left photo the connector is for the key in ignition buzzer.
Question,is this a new M&H harness? If so it will have extra plugs do to 70 charger headlight relay. I believe the double blue is for that on driver side
7
7
Yes it is. Thank you very much!
Bottom left is a crap shoot. Just a guess headlight delay relay. At least thats what the double green should be for.
Not headlight delay relay, but headlight hideaways relay. It should get also a floating plug around with the double blue on background of the pic. For 70 Charger.
A headlight delay relay should ge an extra harness not included into the basic standard equipment harness, since is an added accesory.
Thanks everyone. I think I've got it sorted. Another question however, I don't see the air grabber solenoid anywhere in the SM. I found a diagram of the vacuum routing on here but unsure how the solenoid is electrically connected.
