cwhubb
I was setting up my 440 via dead timing method after an electronic dist swap and I'm second guessing myself. I used a handle from a plastic spoon in the number 1 plug hole found tdc then I backed it off just a hair the piston barely moved down, maybe moved 1 timing degree. I centered the zero on the crank with the timing line. I thought everything was fine till I read an article saying to make a mark at tdc then reverse the rotation till tdc, mark that then split the difference tween the two marks and you have tdc. am I good to go the way I did it? I'm having visions of the piston slaming into the spark plug. BTW I havent started the car yet I'm re wiring the engine bay.
