Hey guys,
Long time, no update...have had not much time with Christmass etc. but in the mean time received my new push rods from Smith Brothers.
Also got myself an oil priming rod to check the oil feed and get oil back in the lifters.
Once all lifters were found stiff, installed the push rods and torqued down the rocker shafts and set the pre load to 0.050" (1-1/4 turn)
Cranked engine over by hand and checked on cylinder #1 the PV clearance which was still found same around 0.130".
Also checked and found both camshaft locations that provide oil to the rockers and found them...plenty oil coming up.
After i had to redo everything to remove the checking springs and install the normal springs and valve seals.
Rotated the engine and checked for any push rod hitting the cylinder head but they all have enough clearance.
I applied 30lb/ft torque on the adjustment screws and 35lb/ft on the rocker shaft hold down bolts.
I was not sure about the adjustment screws but figured 30 should be near enough.
Now not sure for anything else to check right now.
If that's it i will continue and close the valley pan with new cover and intake.
I got myself a new intake from Mancini racing, it is not an Edelbrock but like a copy of it.
Was on discount and since my intake is all cut up i rather install a decent one.
Ony comments or suggestions of what else to check before i close the valley?
