I didn't see any change at all.
No ignition box. Wiring for the coil I took out and this one all come from factory harness and distributor.
I pulled out the old coil and wired this one up exactly the same.
Found this interesting: I turned the engine over until cylinder one was at top dead center. The rotor was pointing to where cylinder 1 is shown, on the dist, in the diagram below:
The way the car was before, the spark plug wire for cylinder 1 was going to number six, on the dist, in this diagram. All wires were in the correct firing order after that.
The seems crazy to me. The car's been parked for a number of weeks, so I could be wrong. But I even wrote the number one on the distributor cap where that wire was going so I'm pretty sure I'm remembering it right.
Could this even be possible?
I'm rerouting fresh spark plug wires according to the diagram above and will start the car to see how it runs.
I swear I've built multiple cars from the ground up. None of them have been older than 10 or 15 years so I don't know I'm having so much of a problem.
