Congrats!
Very nice congratulations. 8.50 next goal??
About a 4-600 shot maybe. Speculating at this point.Don't loose your head.
Good Luck this weekend.No way it'll see 8.50. Maybe an 8.8X in real good air. To be honest when I started this project it was going to be a 10.50 car. A friend had this short block that was passed on to me. It all started with that. It ran [email protected] on it's first pass in 2013. The car runs in Nostalgia Super Stock. 10 2022 NMCA Nostalgia Super Stock 1.1.docx
Started out at the 9.50 B/FX index, then went to the A/FX 9.25 Index. I've been trying to tweak our way into the AA/FX 9.00 index. The engine has been very reliable with the exception of last years mistake. So it has remained with the same basic components since 2013. Compression, heads and porting, cam and valve train, intake, headers, trans, have not been changed. Better shocks, 4.30 in place of the 4.10, converter, 4150 based carbs, crank scraper, air pan, 16v battery (instead of 2 12 volt), Carbon fiber hood. So the car is about 60lbs lighter, driver is about 15lbs heavier. We'll be at Columbus this weekend. Weather is projected to be in the mid 90's so it may have to be backed off to the 9.25 index. We'll see.
Doug
At my age I didn't loose it I just misplaced it and haven't remembered yet where it is. LolDon't loose your head.
Never thought any 9 second much less 8 second would fall into a" low maintenance" category.Car is certed to 8.50. If I was to go quicker I'd build a light car. It's making north of 900hp all ready. the Motor is at it's at the limit of "low maintenance".
Doug
We are talkin bout Doug here. lolNever thought any 9 second much less 8 second would fall into a" low maintenance" category.
thanks, i took the cap off my msd billet dist and found corrosion everywhere, appx 2 years old ! the mag pick up was wasted, and they glue them in also ! i expected more from them than that..i run lock timing also so i think im going to throw in a tach drive DC aluminum housing unit with the slots locked and see how it works...It's a 440 source with nothing but a cap and rotor. The shaft is welded solid. The electronics are a MSD crank trigger.
Doug
