Doug can you post about your weekend of racing. Waiting until Monday is tough.
As long as it doesn't interfere with racing.
Similar story here. Record heat in south Louisiana and Mississippi. Struggling with the last (that I can think of) big project at the vacation house, finished putting up the wooden fence. Hope to be able to start working on my car for the first time in a year and a half.This weekend was a struggle again. Weather was hot.
Fixing the car every week bites. At least you got to race.This weekend was a struggle again. Weather was hot. Track was hot and slippery. Friday made 1 hit at 9.00 index. Decided to go to 9.25. 2nd hit got out of the roove immediately and lifted. Haven't tried to slow the car since 2020 with the Eddy carbs. So now into eliminations with 6 degrees of timing pulled. Way to quick, poor stripe driving and late. Saturday I decide 9.00 or bust. Removed the pass seat and weight bar brackets. Ran with only 2 1/2 gallons of fuel. Track was greasy. Tried shock settings, tire pressure, different burnouts. Got it somewhat consistent. But a few curve ball runs doomed me. Got thru rds 1&2 on good lights. Went to rd 3 against good Friend Jeff Day. He new I couldn't run the number. I knew he could run +/- .01. My only chance was a killer light. Went -.009. Didn't matter as it spun and Jeff was .015. Sunday Q1 was decent. Run #2 spun again. E1 left with a good light saw smoke right after the 1/2 and lifted. Broke the trans cooler. Fluid everywhere. Fortunately the cooler is mounted under the car between the sub frame connector and the tunnel. The entire middle of the car was covered all the way up to the deck lid. Zero fluid outside either connector or frame rail. Tires stayed fluid free. These are Saturday and Sundays runs.
Doug
That's what I was thinking, and Doug's reports are detailed and helpful.At least you got to race.
That's happened here a few times. It seems wrong, "cowardly" for a track to do that, and after you or anyone working so hard, sacrificing time and effort for a track to seem to "take the easy way out" and not "work to be open" is a pisser.Magnolia cancelled Sunday morning because of the forecast. No rain all day.
So, what book is the better-half reading while you’re racing? Talked to u both a couple yrs at Quaker. JeffThis weekend was a struggle again. Weather was hot. Track was hot and slippery. Friday made 1 hit at 9.00 index. Decided to go to 9.25. 2nd hit got out of the roove immediately and lifted. Haven't tried to slow the car since 2020 with the Eddy carbs. So now into eliminations with 6 degrees of timing pulled. Way to quick, poor stripe driving and late. Saturday I decide 9.00 or bust. Removed the pass seat and weight bar brackets. Ran with only 2 1/2 gallons of fuel. Track was greasy. Tried shock settings, tire pressure, different burnouts. Got it somewhat consistent. But a few curve ball runs doomed me. Got thru rds 1&2 on good lights. Went to rd 3 against good Friend Jeff Day. He new I couldn't run the number. I knew he could run +/- .01. My only chance was a killer light. Went -.009. Didn't matter as it spun and Jeff was .015. Sunday Q1 was decent. Run #2 spun again. E1 left with a good light saw smoke right after the 1/2 and lifted. Broke the trans cooler. Fluid everywhere. Fortunately the cooler is mounted under the car between the sub frame connector and the tunnel. The entire middle of the car was covered all the way up to the deck lid. Zero fluid outside either connector or frame rail. Tires stayed fluid free. These are Saturday and Sundays runs.
Doug
So, what book is the better-half reading while you’re racing? Talked to u both a couple yrs at Quaker. Lovely girl. Great job on the car. Jeff
