Disc or drum M/C how to tell
YY1
6:26 PM
FL
Is there a way to tell from the outside if a master cylinder is for disc or drums? I found two out in the shed, and might like to use one if it's for disk.
On a related note, I uderstand the internal difference is a valve that keeps some pressure for the drum. Can this be renoved/modified so the M/C cab be used for disc? IE, during a rebuild from a kit.
Probably should just use as a core but I'd like to know.
Thanks much.
