Disk brake set-up
deerbreeder
New Member
3:23 PM
East greenville,Pa
My buddy has a 65 fury 3 witch I believe is a C body.My question is can you replace drum brakes with a B body disk brake set-up?
I'd contact Dr Diff. He'll get back to you quickly with an answer.
You won't know until you try cause there's no guarantees, but I'm sure someone here has tried it. If the spindles are the same I'd say yes but you're really better to go with an engineered aftermarket system which includes booster, master and prop valve. And, if you're going from manual to power keep the pedal ratio in mind as the two pedal arms are different.
