- 10:00 PM
- Jan 14, 2009
- Shoreline, Washington
Every MSD system instructions, as well as every EFI system instruct you to run primary power and ground direct to the battery.
As does the instructions for almost any kind of aftermarket electrical accessory made. For 99.9 percent of vehicles on the road today, no issue. If that language was not present, most of that gear would be connected to the first wire found anywhere that lights a test light, and/or grounded to a non-conductive dash frame. Most installers of aftermarket electrical equipment (professionals and amateurs alike) can’t seem to locate good clean power connections otherwise.
There is no reason the MSD and EFI (or any other accessory) can’t be connected to the alternator side of the ammeter on these original Chrysler charging systems as originally designed if the conductors/connections are well maintained and appropriately sized for the loads.
