Here are some pics of my solution. Not sure if I qualify for a how to, but this seems to work for my application.
I can now freely rotate even with plug wires on
Clearanced the flange and ground the weld on top also massaged the area to somewhat of a radius instead of a straight 45.
Opened up the bolt holes a little and spot faced for the washers to sit flat.
There was interference between the inside of the flange and the rocker pedestal. I clearance this which along with the enlarged bolt holes allowed me to slide the cover slightly away from the distributor. I was able to maintain good rocker clearance
This is where the cover was touching
Thanks again all!
Thanks again all!
