Geoff 2
69 Net,
You have a lot to learn. In post #8 you say the engine has a lopey cam. The lope [ engine shaking ] is the engine misfiring [ missing ] . The additional overlap from big-ger [ lopey ] cams causes the fresh incoming mixture to be diluted with exh gas which causes incomplete combustion...rough running.
And it WILL take 30* at idle; might need to check timing marks. Millions of cars with small, smooth idling cams idled at 24-26*....& big-ger cams need more.
