TheRealDavid
I'm replacing my master cylinder. So I almost have the nut loose that connects the pushrod to the brake pedal and it's a pain to get it loose. I purchased some cheapo ratcheting wrenches since there is almost no room down there. I couldn't fit a socket in there. I get the feeling that when it comes time to get the rod back in there I may not be able to get my hand in there to get the nut to bite again. Is there some trick to this, do you move the steering column? I'm just going to suck it up and remove it tomorrow and I guess I'll need tiny fingers to get it back on there.
Story time. Feeeeeeeling kinda dumb.
So I had the typical issue of having the annoying rubber grommet stuck in the old master, my master was so messed up that it came off and just left the piston assembly stuck to the pushrod.
I tried to pull the piston off the pushrod and after spraying some penetrant it actually came off. This is all to avoid removing the damn pushrod.
So I have the new master bench bled, a new dr diff grommet on the pushrod.
I'm about to install it and it pretty much sucks that the bolts want to sink back into the firewall and fall in, the pushrod doesn't want to slide in, **** starts to get heavy and I don't want to drop it so I try to pull it back and it also will not come out.
I pull harder and the damn piston pops out while still stuck to the pushrod since the new master only has a flimsy clip to old it in. sh**!
In all this pulling and pushing I may have bent or broken the brake light switch ughhh, I'll investigate this further tomorrow, hopefully I can bend it back in place if I did and maybe replace the switch if needed.
