You could take it off the trailer and drive it over the hill...
Me too. What's the tow rating on your renegade? (Front wd or Four wd?)I have noticed that Wranglers (not looked at Gladiators directly) only have a class II hitch receiver from the factory.
Whereas the factory Mopar towing kit for my comparatively dinky Renegade (FWD Renegade) is a class III.
I find that interesting to say the least.
Maybe.I don't mean to be negative but when your coming down a hill on the freeway and you don't have enough weight in the tow vehicle to keep the loaded trailer stable , bad thing happen in a hurry, I've helped clean up a few
Buy a $1000 trailer from craigslist, use it, then put it back on CL for $1500?
I agree to an extent.As noted above, it's not so much the towing, but the stopping. Yes, even with surge brakes. When the tail is bigger than the dog...you have problems.
I worked for an RV dealer for nearly a decade, so I knows me some towing. The Gladiator has a couple things against it for this use - first, it is rated for a light tongue weight. That means you have to keep the LeBaron towards the rear of the trailer in order not to squat the rear of the Gladiator too far (not only does it look stupid, but it unloads your steering wheels and puts undue stress on your rear suspension, as well as uneven loads on the trailer axles), but a rear-loaded trailer is more likely to sway back and forth.
Surge brakes only work when the trailer has momentum, and is "pushing" on your tow vehicle. Electric brakes are MUCH more competent, and if your Gladiator has a factory hitch it should be pre-wired for a brake controller. Get one. Trust me. I use the brakes on my 26' enclosed trailer to hold my Cummins in place on hills, so I don't fumble the clutchwork and do a burnout...but you can also control the amount of braking force the trailer gets with the turn of a knob, and save the brakes on your Gladiator.
Net answer, though? Get a truck rated to tow your load. No sense risking your Gladiator AND your LeBaron because you didn't want to pony up the $19.95 to rent a half ton truck, to go with the trailer!
This. One less worry for the trip that way.Rent a truck AND a trailer. Easy peasy.
