biomedtechguy
Accelerati Rapidus Maximus
- 3:03 AM
- Mar 28, 2014
- South Louisiana
of course ran open on the street never had a problem
We don't need no stinkin' mufflers !
The video is bad, but the audio is nice...We gunna need some vid with your foot on the the WOT!
Its old school thinking.I'm confused... is this old school thinking? Isn't it far better to have all the tubes equal length to get the most out of your system? Or is this a race only item that has shown no benefit on the street?
I am finally rebuilding my 70 4spd RR and it will have a 440 stroker instead of the NOM cast crank 383 that was in it. I was considering headers, but haven't decided if they are worth the trouble over HP manifolds. The RR will see street duty only.
A 440 stroker? To what size CID?
Search AndyF here or at the on line magazine, “HitRod” where he did a number of dyno tests with exhaust manifolds. And made good power to boot.
Header leaks are a pain. I am fighting a header leak on my 68 Hemi Dart. No friggin way to get enough clearance to replace the gasket. My racing buddy tells me it wasn't meant to be capped up.
4.375 bore X 4.15 stroke. I believe that comes to 499 CI.
10.??? compression for pump gas
Edelbrock E-street heads with angled plugs
1970 HP exhaust manifolds (for now)
1978 factory spreadbore intake (or an Eddy RPM intake, depending on dyno results)
the dreaded Thermoquad (I love the sound)
camshaft TBD
I am looking for a relatively flat torque curve, as much HP as possible, a nice choppy idle without losing a ton of vaccuum and loping like a pig. A street friendly "modern magnum" type cam for a 4spd.
It is not built yet so i can still make changes if need be to make a decently matched system.
I will definitely be looking up Andy's work. Thanks for the tip.
Sorry, but WHY! would you choose me the life out of a 500 CID is engine with OE parts???
Sorry, I just see insanity.....
Do you want to work hard to go slower?
What?
Umm, how?
Its gone 11.60s at over 120. Stock converter and 3.23 gears. 1.9 sixty ft. (i.e. stock suspension). Put a reasonable 60 time on it in a normal weight B body and it would be at 11.30s or 11.40s in good air.
https://www.forbbodiesonly.com/moparforum/threads/post-your-11-second-combos.25226/page-20
Thanks for the advice and the link! Looks like I should forget about hogging out the factory intake and just go with the RPM.
