beanhead
Easily Offensive
So I've been doing some adjusting on my recently-started 440. It's .040 over, with unmodified edelbrock RPM heads and intake, a speed demon 850 carb, comp XE274 cam (.488/.491 lift, 230/236 @ .050 duration, 110 lobe sep.)..right around 10 to 1 (maybe +/- only a couple of decimal points but haven't done an actual comp check yet) 1-7/8 headers out 2-1/2 pipes with dmax super turbos...using the MP orange box/elec. distributor kit I got about 10 or so years ago, autolite AR3933 (non-resistor version of the 3924) My vacuum gauge took a crap so I'm just using the timing light for now. I started the motor with about 16 degrees initial, I've advanced it to the point the rpm just starts to flatten out and I'm at 25 initial, and it kicks up after I increase throttle and tops out at 37 degrees, around 2500 or so...seems like a lot of initial to me, but it doesn't ping or anything and the exhaust temps went down a bit...now, of course this is all in park because I can't drive it yet, which is when it will be fully dialed in...I then set the carb idle stuff and that seems to be real close too...I know every engine likes different settings I just don't really have experience with these higher flowing aluminum heads and this cam, which isn't all that wild or anything but it's definitely a little choppier than stock. Also of note, while I expected it to be a small adventure to start it with no choke, especially this cooler time of year, it sometimes likes to get a small fire going in the top of the carb, which I promptly smother with a wet rag...it might pop once but not real bad while trying to start it, I thought this was usually a symptom of too much advance but it did it when I had it back down around 15 too...and like I said it seems like it wants the added advance when it's running...I've dealt with mostly stock or only slightly hopped up stock stuff over the years so I thank you all for your advice!
