Drum to disc on a 64 plymouth fury
Dads64
New Member
7:36 PM
Cadillac,Michigain
I am looking to convert my fury to front disc brakes without spending alot of $$. Any thoughts on a donor car that might provide a bolt on swap?
I think 78-79cordoba will also work! Early 70"s b-body also.
You don't need to change the any of the controls arms on a B-body.
try M-body 80-85 will work, I have a set picked from junk yard. $55. porportioning valve, spindles and caliber slider brackets. 11 inch disc's.
So far the biggest pain I am dealing with putting M body (87 5th Ave) disks on my 66 is putting the correct fittings on the lines, and bending the lines to use the 5th Ave prop valve. The only exotic part I've had to use is an MP 4 stud to 2 stud adaptor. I figure connecting the prop to the calipers will be the next pain, as I don't think I can use the stock frame tabs that hold the connection between the line and the hose. I have Cordoba hoses to try. The look like they might work, but I'm not there yet. The M body definately will NOT work. Everything else has been fairly smooth.
