Garys1969RR
Was wondering if anyone has tried using E 85 fuel in their engine. I heard about a guy at the local drag strip that runs it in a 451 and his 1/4 mile times are around 11.5 sec et. And this is at 5400 feet! I have a 451 at 12.5 to 1 C/R and have access to the Holley metering blocks that allow use of this fuel. It is rated at 105 octane. The Holley guy that supplies these says that the engine will produce as much power with E 85 (when properly tuned) as it will on Race fuel. Since it is readily available in my area, and is less cost than regular gas, I would like to try it out. I ran it in an old Toyota that was built to run on gasoline for awhile, and no problems. But the MPG dropped. Any first hand experience is appreciated. :eusa_think:
