dieseldazzle
I read your links - pretty damn impressive! I've been thinking about E85 combos lately and have a few thoughts/questions that I'd love to hear your take on:
Your combo was 14.5:1 CR; what do you think a good rule of thumb CR limit for E85 is?
Also, I have been toying with the idea of building an engine set up for both race gas and E85 utilizing Holley's HP Dominator EFI (E85 compatible). Drive on the street with E85 and a compatible tune on the EFI/ignition. When you want to turn up the heat, run the tank down to empty then fill with 104 race gas - run the electric pump (engine off) and bleed the E-85 from the fuel rails. Re-squirt the EFI control module with the 104 race gas tune, fire it up and head to the strip.
You could conceivably do the same with carbs, just needing 2 different carbs you'd swap between fuels.
Thoughts?
I don't understand why you would want to ditch the e85 when you "turn it up"??
I've built single turbo 327 inch small block ford out of my garage that made 960hp to the tire on e85. It is sometimes driven on the street and the pump e85 has always tested great with the analyzer.
My buddy runs the same setup on his Lsa stroked cts v Cadillac daily, no issues.
