munger77
Need help with problem:
I discovered lack of continuity from temp gauge on my '68 cluster to the temp sending unit, and my new OEM wiring is good. The purple (temp gauge) wire from the dash does not make contact with the engine compartment side of the bulkhead connector. It is about 3/4 of an inch inside the dash side of the bulkhead, so it does not make any contact when the bulkhead is snapped back in place. Is there a way to grab the wire from the interior side and pull it out into the firewall side of the bulkhead so I can clip everything back together at the bulkhead and have a working temp gauge?
thanks for any help.
